16 Nov 2023 03:30 PM
16 Nov 2023 04:30 PM
Posted by a Superuser, not a Sky employee. Find out more@sharumag that question does not have a simpke answer as it depends on what work is required and Openreach's availability.
Sky will only know what Openreach tell them which is frequently not a lot. I know thst sounds unsatisfactory but its howcthecsystem works. You should be due compensation oncectge job is complete see Customer Auto-Compensation | Sky Help | Sky.com
16 Nov 2023 04:43 PM
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
