Discussion topic: No wifi
This message was authored by Brendan29 This message was authored by: Brendan29
No wifi
I have had no wifi now for a couple hours. On the router the internet is not lit up. I have done the online service check for my broadband and wifi but it says everything is fine when i have no connection.
Re: No wifi
@Brendan29  So you have no broadband was this what you used to check if your broadband was working correctly
https://www.sky.com/help/servicestatus#/uk/issues
or was it this below that you used to check your broadband status
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
