Discussion topic: WiFi is not working
This message was authored by Emma291 This message was authored by: Emma291
WiFi is not working
WiFi has stopped working when tested it says it's fine but is red on box
Re: WiFi is not working
@Emma291Is this the test that you are running from the link shown below.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
