Discussion topic: Ip address
This message was authored by Mandy26 This message was authored by: Mandy26
Ip address
How do i find my sky ip address. My ps4 wont connect to it
Re: Ip address
@Mandy26
You should not need your Sky routers LAN IP to connect a PS4 it will configure itself if the connection is there. Are you using WiFi or Cable?
I am NOT a Sky Employee
