Discussion topic: EH4 intermittent broadband dropping
This message was authored by Chamberswatt This message was authored by: Chamberswatt
For the last couple of days my broadband keeps dropping. It's for a very short period of time usually just a couple of minutes but it's really annoying. I've done the usual checks and it says everything is working fine. Is there anything I may not have tried? How can I tell if it's an issue with the cable for example?
Re: EH4 intermittent broadband dropping
@Chamberswatt Could you please post your router stats following the link below.
Chamberswatt
 this is when it goes offline
Chamberswatt
 and this is when it is off. It's going off every 5-10 mins now
@Chamberswatt  What you posted is not your router stats so the images can't be approved, this link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
You need to follow through to the very end.
Chamberswatt
Did those work? That was a full 30 minutes before it dropped off again
@Chamberswatt  No you need to post the router stats as explained in the link provided earlier.
Which hub do you have?
Chamberswatt
Ok that's what I thought I had done , I suppose it doesn't help that my 3G doesn't work very well in the house so I'm basically offline lol
Chamberswatt
I can't sign in, I've tried the password from the box and the default. It just refreshes to sign in pop
up
@Chamberswatt that can happen with ios devices if **bleep**ible use a non-Apple device or if stuck use Chrome rather than Safari.
Chamberswatt
Thanks I tried that but it just does the same thing! So frustrating it's literally on and off 4 times an hour 🙈
