28 Nov 2023 03:39 PM
28 Nov 2023 03:52 PM
Posted by a Superuser, not a Sky employee. Find out moreSometimes it can take Sky longer to answer the phone during busy times, you just have to wait. It is in no way breach of contract if you havent even reported the fault to Sky yet.
Also what 'non-sky' devices are these? If your testing your speed over WiFi then its quite likely to be lower than 100mbps because Sky do not guarantee the speed over WiFi, only ethernet. Have you tested your speed over ethernet?
