21 Feb 2024 05:35 PM
Hi. I have a SE210 booster and am hoping to use it to provide better Wi-Fi coverage in my summer house at the end of the garden which is a bit too far from the house to get good signal.
The plan is to run an outdoor ethernet connection from my sky q hub down to the summer house and then plug the cable into the booster which can then use this connection to beam out the Wi-Fi.
whilst I appreciate this isn't a very technical description - I was hoping someone on here would be able to tell me if the plan would work.
thanks in advance
21 Feb 2024 07:03 PM - last edited: 21 Feb 2024 07:05 PM
@PabloLeone There should be no problem in doing what you intend, the booster does work in both ways, as wirless to ethernet, and ethernet to wireless. You may have to factory reset it if you are using it currently in the opposite way, but i would just try it first. You can also try it in the home, to test before you carry out all the work.
26 Mar 2024 10:53 AM
Hi Did this work as Im doing something similar this weekend?
