24 Nov 2023 06:22 PM
Hi I am having constant slow connection.
I have sky broadband ultra fast 1, broadband boost and sky q box and multi room box.
I will upload my router settings if someone could please let me know if these are correct.
I have tried the support page and I have spent 37 minutes on the phone to sky technical.
I told him there is option on there of a log for sky tech team but I was told he is unable to access this..
(Outcome was there nothing wrong even though it clearly says on my sky app)
Is the new fibre line not correctly installed do I still need to be using the the old line as currently there is a lead coming from there?
I will attach photos.
Sorry for so many photos of speed tests these are from separate parts of my house.
Thank you
24 Nov 2023 06:30 PM
Posted by a Superuser, not a Sky employee. Find out moreGiven you appear to have a live connection to the white Openreach ONT, you shouldn't still have the wall socket connected to the purple socket on the rear if the Hub.
I'd also suggest using the Sky-supplied ethernet cable between the ONT and the Sky Hub WAN ethernet socket (#4)
25 Nov 2023 10:48 AM
25 Nov 2023 05:33 PM - last edited: 25 Nov 2023 05:34 PM
Posted by a Superuser, not a Sky employee. Find out moreIn that case one would suspect you have a live Superfast FTTC connection arriving over the wall socket, and the switch to Ultrafast over FTTP through that ONT has not happened.
25 Nov 2023 06:46 PM
Okay I am lost now, I assumed it was fibre direct to premises.
I can't understand these results but hopefully someone could see what these results mean?
25 Nov 2023 06:48 PM
28 Nov 2023 02:48 PM
Posted by a Superuser, not a Sky employee. Find out moreYour router stats show WANoE as the connection type so it is using FTTP as the connection method. Can you try leaving the purple cable unplugged and giving it a few reboots just to see if anything starts working in terms of the voice light and your connection?
