28 Nov 2023 05:26 PM
Hi all,
Looking to connect a smart bulb to my WiFi and it seems it won't connect as it must be at 5ghz currently.
So if I untick the synchronise box, connect the bulb up, is it possible to then change back so the 2.4ghz and 5ghz are synchronised?
28 Nov 2023 05:45 PM
Posted by a Superuser, not a Sky employee. Find out moreYes that should work for most smart devices but not all so you'll have to test
