Discussion topic: How do I get Sky Max?
This message was authored by: Darrener
I want to watch Brassic. I am told it is available On sky max. How do I install this app?
Re: How do I get Sky Max?
@Darrener
Are you a Sky TV customer in the UK, if so you should be able to find it on the Sky Go app.
@Darrener
'Sky max' is not an app.
The 'Sky Max' channel has closed: both it and 'Sky Showcase' were replaced by the re-launch of the 'Sky One' channel in February 2026
If you subscribe to a Sky or Now television package then any Sky Original series such as Brassic should be available on-demand.
Perhaps note that Sky Go isn't available as a standalone app: it's a 'free' add-on to a Sky Television hardware subscription.
This message was authored by: Timelord2018
Sky Max was rebranded back to Sky One on 24th February after 4 and half years and moved back to Sky Showcase EPG position which was shut down.
In addition to all above S1 to S7 of Brassic is available On demand on my Sky Stream, so assume same on other Sky platforms.
It's listed in On demand under Sky One.
Available in quality up to UHD/HDR and Dolby Atmos.
A manual or voice search will bring it up.
If you want to watch via an app then you can via the NOW TV app. Available on most smart TV's and streaming devices.
All 7 seasons of Brassic are available with a NOW Entertainment subscription, in up to UHD/HDR quality with Atmos audio.
Subscriptions cost from £4.99pm but can be cheaper if you opt for a 6 or 12 month saver plan.
