Discussion topic: HBO Max
This message was authored by: MarcMarquez
HBO Max
I Just activated HBO Max on my Sky TV. i had been watching the Sopranos via Sky Atlantic, Now The Sopranos is only availabel through HBO and i have to endure non stop adds to watch which is unbearable. how can i deactivate HBO MAX and go back to viewing on Sky Atlantic where i have control of the adds?
Re: HBO Max
If you don't want to use it then you don't have to but certain content like The Sopranos will not only be available via HBO Max as they are the content holder so the days of programs like this being available via just Sky Atlantic are over I'm afraid.
Re: HBO Max
@caesarome wrote:
If you don't want to use it then you don't have to but certain content like The Sopranos will not be available via HBO Max as they are the content holder so the days of programs like this being available via just Sky Atlantic are over I'm afraid.
@caesarome Think that should read will only be available ?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Re: HBO Max
hi @MarcMarquez
To be clear,  your personal activation of HBO Max has had no impact on the availablity of content via SKY Atlantic - so deactivating HBO Max would   make no difference to what is availble to you. via SKy Atlantic but it could restrict access to content that may only be availble via the app.
SKY and the HBO Max owners (WBD) have long standing deals which allows content to be used on SKY but with WBD launch of HBO Max they have more control over what is shown on both platforms.
Clearly at launch HBO Max want to maximise their viewers so some content that was previously on SKY Atlantic may not be any more - although some may return for defined periods
This message was authored by: Timelord2018
Re: HBO Max
Anything that was part of the old HBO output deal (Pre April 2022) Sky no longer has the rights to and seemingly the early 2026 series will only be available for 6 months from their premiere date.
This message was authored by: Me134
Re: HBO Max
Unpalatable as it may be, you can of course pay for the Ad free option on HBO.
Not a Sky employee
Sky Q with 2GB UHD box using WiFi
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
2 Windows desktop PC's hardwired to each Deco, everything else using WiFi
Re: HBO Max
It's probably important to understand that Warner Bros Discovery Ltd, the current owners of HBO, think that Sky has been underpaying for HBO content over many years (and also effectively delaying the launch of Max in the UK) : the eventual expiration of the previous long-term contract with Sky Atlantic made under different ownership means WBD is back in full control of that extremely valuable back catalogue and they really need to demonstrate to some fairly disgruntled stockholders that they are now going to maximise financial returns.
