Discussion topic: Freeview channels through Sky+HD box
This message was authored by: shnookumshnum
I have heard a rumour that sky will be removing the ability to watch freeview channels through a Sky box without a subscription, any truth behind this?
Re: Freeview channels through Sky+HD box
@shnookumshnum  Yes it's true but it only applies to sd only boxes hd boxes will still continue to work as normal
FreeSAT 😈
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Or even more correctly FTA sd channels😉
This message was authored by: RobertS83
If you still get BBC channels on your box you are not affected.
If your box is affected and you havent changed to Sky Q or Stream/Glass, your subscription for Sky TV will end unless you contact Sky to upgrade your box.
I am neurodivergent with Dyspraxia
Sky Stream with Sky Ultimate
EE Full Fibre 900Broadband
Fire TV Cube
Xbox Series S
Roku Streambar
Apple TV
