Discussion topic: phone not accepting incoming calls
This message was authored by: northwales2
landline not accepting incoming calls. Can phone out on it
Re: phone not accepting incoming calls
@northwales2
Has it previously been working okay?
This message was authored by: kiwi1
We are exactly the same, it started yesterday
@kiwi1 @northwales2
Try the below line test. Disregard it saying it will test your broadband https://www.sky.com/help/articles/fix-phone-problems-start
If you're able to make outgoing calls have you reported a fault by dialling Sky on 150?
There is currently an issue in the Sky network and is under investigation.
