Discussion topic: Water leaking in
Message posted on 08 Nov 2023 11:28 AM
Water leaking in
I have water coming in my house through conduit with phone cable..cant find anyone to speak to
Message posted on 08 Nov 2023 11:33 AM - last edited: 08 Nov 2023 11:34 AM
Re: Water leaking in
And what has this to do with Sky @Alicechris
Message posted on 08 Nov 2023 11:35 AM
Its coming in with the landline
Message posted on 08 Nov 2023 11:36 AM
Looks like you possibly need a builder and not Sky @Alicechris
Message posted on 08 Nov 2023 12:12 PM
As @oldfella indicates, it's unlikely to be within the remit of Openreach to remedy that unless you can demonstrate they carried out a negligent installation: for example not allowing a drip loop. Even then, there's not any straightforward way of getting an ISP to book an Openreach investigation without an actual broadband or voice telephony fault.
Message posted on 08 Nov 2023 12:16 PM
My sky installation works well had been in 2 years.this is an old cable from previous people not capped off
Message posted on 08 Nov 2023 12:42 PM
@Alicechris wrote:My sky installation works well had been in 2 years.this is an old cable from previous people not capped off
@Alicechris In that case it's not a problem related to Sky, get a local builder or handy man to seal the hole or do it yourself with some silicone sealant.
