16
This discussion topic has been answered Discussion topic: Switched to sky max router from bt sky talk doesnt work
This message was authored by: Si0319
I switched from bt to sky superfast with the sky max router,i have bought a new dect phone and plugged it into the hub,but i have no dial tone and i cant make or receive calls on the landline.The broadband works fine.when i try to ring my landline i get a message saying"this number is temporary unavailable." I have tried all the steps in the online guide to fix it but still nothing.
Re: Switched to sky max router from bt sky talk doesnt work
When did you change to Sky take place ?
Avatar for Si0319
Monday 22.4.
If you have rebooted your hub then run the test here to see if a fault is found:
Avatar for Si0319
The broadband test is fine,i still have no dial tone and i cant make or receive sky talk calls through my sky max router.
@Si0319  Have you rebooted your router since you got Sky broadband?
Avatar for Si0319
Yes, ive rebooted and reset it for 30 secs.
@Si0319  Has the voice light on your router come on at all or what colour is it?
Avatar for Si0319
I only have one light on the max router and thats white.
@Si0319  Sounds like that the voice side did not complete the change over from providers.
@caesarome  Have you come across this happening before?
@Highlinder
I can't recall to many on here but I don't see everything posted so it might have happened to others before.
@Si0319
This link explains how this works so you will need to respond to the chat bubble at the bottom of the page when it appears:
When the chat bubble does appear you will need to respond to it as soon as you can or it will be closed if there is no response within 48 hours.
This isn't a live chat so replies are not instant.
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to @Si0319.
This message was authored by: Chilli1806
I am having the exact same problem after switching yesterday.
This message was authored by: Ylime
I am having the same problem. Switched today. Cant make or receive calls. When calling it says the number you are calling is temporarily out of service. Is there a number i can call to get this sorted?
This problem is still not resolved after 4 days
