This discussion topic has been answered Discussion topic: Sky Max Hub restart light sequence
Message posted on 18 Dec 2024 12:01 AM
Anybody able to confirm the light sequence when restarting the white Sky Max hub with full fibre connection?
I get solid amber for a little while, then a slow flashing green, briefly a red and then white. Total restart around 1m 30secs.
My landline isn't working (broadband all good) and I'm wondering if the brief red light is a clue, if others do not see a red light at any point during startup
Message posted on 20 Dec 2024 11:48 AM
Note that after Sky said it was working, I did try turning my hub off and on again. The startup light sequence was exactly the same - momentary red still showed. Wired and wireless connections were all working again almost immediately. Landline took a few minutes longer to start working again. Was panicking for a bit 😅
Message posted on 18 Dec 2024 05:43 AM
Re: Sky Max Hub restart light sequence
If you haven't already try running the line test here to see if it finds any issue with your talk service::
Message posted on 18 Dec 2024 09:42 AM
All tests are good. I was specifically wondering if a momentary red light on hub during startup was normal or not
Message posted on 18 Dec 2024 11:50 AM
Not sure this helps much but I too have lost telephony & have the same startup sequence.
Yesterday my phone was reporting a line chord error. Today that's disappeared but I have no dial tone. Seems to be yet another failing of the very poor Max Hub.
Online diags ask be what colour the Voice LED is, when of course this router doesn't have one...
Message posted on 18 Dec 2024 01:17 PM
I'm assuming your phone is plugged into your Max Hub. Try resetting the Hub, by pressing and holding the WPS button for 30 seconds.
Message posted on 18 Dec 2024 02:53 PM
- Got a text from Sky to say they've fixed it - and they had - could make and receive calls. Turned hub off and on to see if red light would still show during startup - it did. Landline not working again!
Message posted on 18 Dec 2024 02:56 PM
It's working again 😅
Obviously takes longer to reconnect Sky Talk than Broadband
