Discussion topic: Re: Landline problem
Message posted on 27 Sep 2026 01:26 PM
Hello. We have the same issue. We had full fibre installed on Friday, switching from a copper line for anytime calls, to VoIP.
There is a dial tone to the landline but we found after Openreach left that we could not call out or receive incoming calls.
Though of course the base set is plugged in to power and the correct socket on the router.
I'm not sure if this should work immediately or we have to wait for Sky to do something to switch across the landline fully.
Message posted on 27 Sep 2026 01:44 PM
@Grim26 yours is not the same issue so I've moved your post accordingly to a new thread.
Yes, it often takes a working day or so for Sky/Openreach to move your service to your new fibre line - it took about 10 days in my case. I'd suggest leaving it until Wednesday and if it's then still not working, restarting both your broadband Hub, and the ONT by switching off at the plug for 30 minutes (if you have a white Hub, leave it for an hour). Let us know how you get on.
