Discussion topic: Problems with Sky Talk
Message posted on 12 Jun 2025 06:31 PM
My elderly mother is having problems with her sky talk. She is getting loads of interference during calls, both ends. She has microfillters on the line but still experiencing problems. Sky say there are no problems with the line. Can anyone please advise 🤔
Message posted on 13 Jun 2025 06:09 PM
Re: Problems with Sky Talk
@kc60 Have you had someone if you are unable to change out the microfilters if they have not already tried this to fix the issue with the interference?
Message posted on 13 Jun 2025 06:41 PM
I agree with @Highlinder . The first step would be to replace all microfilters, and to make sure there's a microfilter fitted to each connection to the phone line, including any extension sockets.
Message posted on 13 Jun 2025 07:46 PM
New micro filters have been fitted to no avail
Message posted on 13 Jun 2025 07:47 PM
New micro filters have been fitted but thank you for your response
Message posted on 13 Jun 2025 10:31 PM
@kc60 Does your mother also have broadband with Sky and if so does she have issues with this also?
Message posted on 13 Jun 2025 10:38 PM
Yes she has broadband and no issues
Message posted on 13 Jun 2025 10:42 PM
@kc60 Has your mother a spare phone to try and see if it is the phone that is the issue, as normally with interference you would also have broadband issues. If the filters have been changed out. Trying another phone with discount it being an internal issue if you are hearing the same interference.
Message posted on 13 Jun 2025 10:44 PM
Thank you, will try on my next visit
Message posted on 13 Jun 2025 10:51 PM
@kc60 If that comes back the same interference then get in contact with Sky and tell them what you have already done. This way it will shorten the need to troubleshoot what has already been done.
