Discussion topic: Problem with landline. Broadband is working
This message was authored by: Codborornum
My landline is not working. The broadband does work. There seems to be a dial tone but if I phone any number I get an engaged tone. If I dial in I just go straight through to the sky voicemail recording. Open reach were working on next door recently but if they had disrupted the line would not the broadband be down as well. I do think this will be an Openreach problem.
Re: Problem with landline. Broadband is working
See if you can run this line test to see if a fault is found outside of your property and if something is found you can book an engineer repair:
https://www.sky.com/help/servicestatus/broadband-and-talk
You can also run this test via the MySky app.
