Discussion topic: Phones that work with FTTP with 3rd party router.
Message posted on 26 Sep 2023 05:30 PM
Hey all,
I've recently upgraded to FFTP but I do want to use my current router setup as it's just better in every way.
The main issue is the phone line which I have to connect into the router. Do you know if there's any I can just connected via WiFi instead of needing the port.
If I can then I can use my Asus routers with it.
Thank you in advance
Message posted on 26 Sep 2023 05:32 PM
Re: Phones that work with FTTP with 3rd party router.
The only connection to Sky Talk is via the physical socket at the rear of the Sky Broadband Hub, I'm afraid.
@aisback To use Sky's voip it must be connected via their hub, there is no 3rd party router that will allow you to use Sky's VOIP service.
Message posted on 26 Sep 2023 05:35 PM
What do you guys think is the best option. I imagine I can turn off the wifi and run that through the asus router.
Is that possible?
Message posted on 26 Sep 2023 05:53 PM
If not I guess Sky Max would be the best way forward?
