Discussion topic: No incoming or outgoing calls
Message posted on 24 Oct 2023 09:36 PM
I,ve just received a text message from a friend to say that she thinks our landline isn't working as it's saying the number is temporarily unavailable. I've tried to unplug and plug the phone in to the micro filter , I've unplugged the micro filter and plugged the phone directly into the socket and also changed the batteries in the phone, but there is no dialling tone at all. I've also tried to call the phone from 2 different mobiles and am getting the same message. Can anyone help please? Thanks 🙂
Message posted on 24 Oct 2023 09:46 PM
Re: No incoming or outgoing calls
See if you can run this line test to see if a fault is found outside of your property and if something is found you can book an engineer repair, ignore the fact it says it will test your broadband:
You can also run this test via the MySky app.
Message posted on 25 Oct 2023 07:22 AM
@speder28greenCan I ask have you recently joined sky from a previous provider? The reason I ask is because this was exactly the same that happened to myself after joining sky from bt. sky sent an engineer out and it turns out my provider i left transfered BB but claimed "Part of the order got stuck"!! when in fact they were just being awkward and soon as bt were contacted my phone worked instantly.
