Discussion topic: Mobile wifi roaming
This message was authored by: Mlauraoflondon
Mobile wifi roaming
I only have three green lights on my router and I should have 4. The one marked voice is not lit. I have two boosters and the middle light is not lit in either of them ... I. Am not able to make calls even to sky for help... I can get calls but i can't make any ... I can get and send texts .... sometimes .... sometimes not ... the tv is working ...
can anyone help me to fix my phone so I can receiver calls Iin The house ???! Please !  🙏🏻
Re: Mobile wifi roaming
@Mlauraoflondon
See if you can run this line test to see if a fault is found outside of your property and if something is found you can book an engineer repair, ignore the fact it says it will test your broadband:
https://www.sky.com/help/home/broadband/my-broadband-speed/no-connection-slow-wifi/articles/broadban...
You can also run this test via the MySky app.
Let us know how you get on.
....and has your phone ever worked correctly, when plugged into the Hub? Does it work when plugged into the normal wall socket?
