Discussion topic: Landlinefaut
Message posted on 20 May 2026 01:32 PM
Landlinefaut
Message posted on 20 May 2026 01:37 PM
Re: Landlinefaut
@rong Is this a New Broadband install or an existing service with Sky?
Message posted on 20 May 2026 04:15 PM
Re: Landlinefaut
New
Message posted on 20 May 2026 04:18 PM
Re: Landlinefaut
If you are a new Sky Broadband & Talk customer it is quite normal for the Sky Talk landline to not operate fully for 24+ hours after the broadband activation.
Message posted on 20 May 2026 04:23 PM
Re: Landlinefaut
I changed to superfast broadband over 3 weeks ago
Message posted on 20 May 2026 04:30 PM
Re: Landlinefaut
@rong is your phone plugged into your broadband Hub? Has it ever worked correctly following the switch to Superfast? If you have a black broadband Hub, is the Voice LED on the front panel illuminated? Amber or green?
Message posted on 20 May 2026 04:35 PM
Re: Landlinefaut
Broadband ok all green
Message posted on 20 May 2026 04:40 PM
Re: Landlinefaut
@rong what about the other questions?
Message posted on 20 May 2026 04:57 PM
Re: Landlinefaut
Yes to all butthephone
Message posted on 20 May 2026 05:05 PM
Re: Landlinefaut
@rong you mean the phone isn't plugged into your broadband Hub? If there are four green lights at the front of your Hub, then your phone needs to be plugged into the socket on the Hub's rear panel. It won't work from a wall socket.
