Discussion topic: Landline doesn’t work as no signal
This message was authored by: Simontansley50
my landline phone doesn't work as no signal even though it's part of my broadband talk package, which I'm still paying for this issues been going on for months how do i get to the bottom of this problem
Re: Landline doesn’t work as no signal
What have Sky said about it?
DId this start at the same time as you switched to Sky?
This message was authored by: Tanley
No
@Tanley wrote:
No
@Tanley
Are you @Simontansley50 using a different log in for some reason? You haven't answered the first part of the question. If this has been faulty for months surely you've already reported it to Sky? Does your broadband hub have a voice light on it and if so is it lit?
Hi yeah I've replied and no haven't reported it as don't know how to online and I don't want to use credit as it will take it all on one call to you landline is plugged in and not signal to call out or to receive calls and the other reason why I haven't cause been to busy as well either way I'm still paying for it
Well, yes, Sky won't know there's a fault until you report it.
You could try the connection test here, even if your broadband is working ok. If it detects a fault, you'll be able to book an engineer there and then.
Otherwise you'll need to contact Sky. If you post back on the 28th we can ask Sky's messaging team to contact you here via a private online chat so that you can do that.
Hi I've done the Wi-Fi check and Wi-Fi is good just my line doesn't work
@Tanley
You will have to call Sky to report it at the moment. Calls to the 0333 number are normally inclusive in mobile packages.
