Discussion topic: Land phone - no incoming/outgoing call
Message posted on 26 Sep 2022 01:50 PM
My land phone is not working. Displaying a message'check phone line'. Not able to make call or not receiving calls.
Message posted on 26 Sep 2022 01:53 PM
Re: Land phone - no incoming/outgoing call
@SNCDid this just happen out of the blue, or have you just moved or upgraded your package with Sky?
Message posted on 26 Sep 2022 02:06 PM
Message posted on 26 Sep 2022 03:35 PM
Message posted on 26 Sep 2022 05:39 PM
Will anyone from Sky help to resolve this issue?
Message posted on 26 Sep 2022 05:43 PM
We're primarily a customer Community. Happy to try to help if you can give us the background details requested. Otherwise by all means give Sky a call to speak to them directly.
Message posted on 27 Sep 2022 10:41 AM
My phone is also displaying 'check phone line' please can someone help me how to resolve this? Thanks
Message posted on 27 Sep 2022 11:04 AM
@BlackstockB Are you able to answer the questions asked about when and how this happened. This way we can help you further.
Message posted on 27 Sep 2022 11:48 AM
this happened on 23.09.2022 and hasn't been working since. The broadband was also off but I have fixed that issue and that is now working fully but still no landline.
Message posted on 27 Sep 2022 11:55 AM
@BlackstockB What did you do to fix the broadband?
Message posted on 27 Sep 2022 12:29 PM
@Highlinder switched it off and then unplugged the blue wire then put it back in and reset the hub
Message posted on 27 Sep 2022 12:33 PM
@BlackstockBWhich hub did Sky supply you for your broadband from the link below.
If it is the first or second one can you run the troubleshooting in the link below.
https://www.sky.com/help/articles/fix-phone-problems-start
If it is the third router that you have does it have a voice light and is it lit?
Message posted on 27 Sep 2022 12:52 PM
@Highlinder It is the first one but I have already done all those checks, all the wires are intack but the phone is still displaying 'check line' and there is no dialing tone.
Message posted on 27 Sep 2022 12:54 PM
@BlackstockBDo you have another means of contacting Sky in order to report this fault?
Message posted on 27 Sep 2022 12:57 PM
@Highlinder yes I do, I have been trying to look for a number but cannot seem to find one suitable for reporting the issue.
