Discussion topic: Intermittent fault with caller ID not reporting number
Message posted on 09 Nov 2023 12:59 PM
As title.
Caller ID on a copper connected line sometimes fails to identify the incoming call number & associated name tag.
Yet sometimes it displays correctly.
Friends & family not withholding there numbers / calls from mobiles & landlines are affected, just random loss of the incoming ID on incoming calls.
It dose seem to be more of an occurrence now than it used to be.
The issue has been going on for some time,
but with the need to replace our Dect phones recently, I can rule the actual phone as the cause, as the same intermitten fault is present.
Anyone any ideas?
TIA
Tom...
BELIEVE =accept that (something) is true, especially without proof.
BETTER = of a higher standard, or more suitable, pleasing, or effective than other things or people:
Sky Q & 2 mini’s
SR203 router. > Replaced with ASUS XT9’s with a TP-Link TD-W9970 modem
Sky superfast 80/20 :sort of, 63-75/15. Devolo 1200 wifi > Replaced with cat 6
Sony KDAF8 65 oled.
Message posted on 09 Nov 2023 01:23 PM
Re: Intermittent fault with caller ID not reporting number
I am having the same problem. Bought a new Panasonic dect phone and caller ID is now intermittent. Very disappointed.
Message posted on 09 Nov 2023 03:47 PM
Typo in OP
The need to replace our Dect phones recently, I can rule out actual phone as the cause, as the same intermitten fault is present.
@jewers I always thought it was a sky issue, but only confirmed when I swapped my Dect phone out.
At least I know I'm not the only one affected.
Tom...
Sky Q & 2 mini’s
Sony KDAF8 65 oled.
Message posted on 09 Nov 2023 03:57 PM
I have seen a couple of other messages over the past few months complaining about loss of Caller ID. When I was with BT is was fine and then the problem appeared when I moved over to Sky.
Message posted on 09 Nov 2023 04:00 PM
I lost Caller I.D. function 2-3 years ago. There had been no recent changes of any kind. Reported to Sky and sorted by Openreach within a day or two without having to come to the address so presumably an issue at the exchange or green cabinet.
Message posted on 09 Nov 2023 04:17 PM
@Daniel0210 Cheers for the info.
A possible easy fix then.
Tom...
Sky Q & 2 mini’s
Sony KDAF8 65 oled.
Message posted on 10 Nov 2023 03:17 PM
@TomThumb5ive I telephoned Sky this morning but did not make any progress with the intermittent caller display. I would really like OpenReach to look into this but all I was told was that my line test showed no faults. I would be most grateful if you could let me know if this problem gets resolved for you. Many thanks for your help.
Message posted on 11 Nov 2023 10:35 AM
@jewers With the rollout of fttp in the local area & hopefully going live soon, I'm holding off reporting this caller ID error to sky for now.
The anticipated move over to a digital line (voip) should resolve the annoyance I've had with caller ID in the past. But will update accordingly.
I'm not much help, but at least you know you're not the only one experiencing this annoying fault.
Tom...
Sky Q & 2 mini’s
Sony KDAF8 65 oled.
Message posted on 11 Nov 2023 10:51 AM
@TomThumb5ive Hi Tom. Many thanks for getting back. It would be great if you could let me know if VOIP solves this problem when you get it. I think I am going to have a longer wait as no mention of it here. As you say, at least I am not the only one whose caller display is not working as it should.
