32
Discussion topic: Help Telephone specific issue
JimM1
This message was authored by JimM1 This message was authored by: JimM1
Re: Help Telephone specific issue
@mae-3
Looks like you are making life easy for me, Vodafone with digital voice package,
and vonage attached to my sky fttc would be the way to go, if vodafone can take
line which may not be to much of an issue, let them do there thing and cancel sky when
everything is complete. If this correct then you are a star👍
This message was authored by mae-3 This message was authored by: mae-3
@JimM1
The question you need to ask Vonage is whether they will peer with G.722 codec HD Calling VoIP services providers because some services use other Codecs that aren't compatible across peering HD Calling providers.
Digital Voice is G.722 which is the most supported HD Calling Codec standard and supports 7Khz width HD calling which is high quality.
Zen internet on FTTP (900Mbps down, 100Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS. Dr Mae-03 PhD.
JimM1
@mae-3
Thanks, took a note of your suggestion and will ask when i call them.
Will keep you posted with the result so you know, allready checked out
vodafone for broadband with digital voice, and they can take the number....
Thanks ever so much for your help.
Jim
On average, new discussions are replied to by our users within 80 minutes
