This discussion topic has been answered Discussion topic: Help Telephone specific issue
Message posted on 03 Jan 2024 04:23 PM
Re: Help Telephone specific issue
Thanks for the reply, would i also be better to try and get on FTTC instead of the ADSL or does that not matter, with HD VOIP solution.
Message posted on 03 Jan 2024 04:28 PM
For VoIP HD Calling which Sky VoIP solution doesn't support, seek an alternative VoIP provider and ADSL2+ is fine for HD Calling if that is all you are interested in on the line concerned and light internet use.
But generally speaking, it is best to upgrade to an FTTC service if available it is usually cheaper and far more future-proof.
Message posted on 03 Jan 2024 04:33 PM
The issue was the 1.1mb/s up speed that the ADSL gives, he said 1.3mb/s would be required min so the
ADSL does not cut it, and i agree future proof etc all good.
Not so much concerned with cost, allready got Talk and paying the £12 for unlimited call package, so he basically has the fixed cost, and no surprise on billing.
Thanks for your advise, will look to see what i can do now.
Jim
Message posted on 03 Jan 2024 05:22 PM
Have spoke to sky. It appears that i have to cancel the contract, pay the penelty fee, redo another contract at a higher price? The cancellation will be both the Broadband and TV and new will be
Broadband only would this be correct, i just do not understand seems so strange.
And the offer is only to Superfast as i know that is all he can get.
Seemingly it's not the best offer, but that is as good as it get's.
Message posted on 03 Jan 2024 05:32 PM - last edited: 03 Jan 2024 05:32 PM
It doesn't sound right to me. It's unusual to be penalised for upgrading and I don't see why your TV contract comes into the equation. Maybe others will have a different view.
Message posted on 03 Jan 2024 05:44 PM
The broadband and TV packages will be different contracts, and I agree with @Mark39 that doesn't sound right at all talk to another agent in Sky who knows what they are talking about. 😎
Message posted on 03 Jan 2024 06:02 PM
I agree, but the advisor was addemant that there was no option, currently trying to find out
if VM do HD VOIP calling and will go back and pay the cancellation charge.
As i say really do not want to waste the time waiting to find more problems and it could
be just the bad line, as was not used on BT for 25yrs as he was on VM.
But thanks for all your help, and i honestly do not care and will pay the exit fee and exit the contract.
Jim
Message posted on 03 Jan 2024 06:03 PM
VM don't do VoIP HD Calling either...
Message posted on 03 Jan 2024 06:05 PM
Message posted on 03 Jan 2024 06:12 PM
You can always add HD Calling VoIP with a third party. The cost of an ATA box is about £30 and a subscription from £6 per month for a hundred minutes free, higher unlimited call packages are available from these third parties.
Message posted on 03 Jan 2024 09:31 PM
Thanks for the help can anyone answer following.
1. Need to keep landline number as he has had it for 60yrs, and does VOIP HD required for both ends
off the connection, not sure of this.
2. Will need to cancel sky no issue with that, looking to go with Vodafone FTTC, dont really want to go back to VM.
Number is the big issue, and would some one like vonage be good, trying to establish if VOIP HD is with them.
Message posted on 03 Jan 2024 09:45 PM
Vonage supports VoIP HD Calling and both ends need to support HD Calling over VoIP. As for keeping the phone number then as per Ofcom, the telephone number should be portable to other providers.
Message posted on 03 Jan 2024 09:52 PM
I would suggest great caution. Check with both Sky and your intended new supplier. There are numerous examples here of number porting failures.
Message posted on 03 Jan 2024 10:06 PM
Vodafone also support Digital Voice which is VoIP with HD Calling.
Message posted on 03 Jan 2024 10:07 PM
