This discussion topic has been answered Discussion topic: Digital Phones Using BT Openreach equipment
Message posted on 09 May 2024 04:47 PM
Will BT openreach swap me over to digital phones or will a sky engineer do this.
Message posted on 09 May 2024 05:04 PM - last edited: 09 May 2024 05:04 PM
If you're switching to Sky, you'll be sent a broadband Hub with a phone socket at the back. Simply plug your phone handset into the socket. No other setting up is required.Note that a phone designed specifically to work with BT Digital Voice won't work with Sky's digital phone service. You need a standard cabled phone handset or DECT cordless phone.
If you have any problems, just post and someone here will try to help.
Message posted on 10 May 2024 08:45 PM - last edited: 10 May 2024 08:51 PM
Re: Digital Phones Using BT Openreach equipment
As @Mark39 indicates, the preparation for the switch-off of PSTN is expected to be largely customer led, with ISPs working in the background to reconfigure their services and send out routers with phone ports when required. Frankly there aren't enough engineers in the world to carry out the project by the end of next year if home visits were anticipated as being necessary in most cases.
Message posted on 23 May 2024 11:10 AM
As and when the digital service is up and running will I still have Sky Talk Shield? I find this really good as no longer get nuisance calls. I can also block any numbers I no longer want calls from. I would much prefer to keep my existing landline as am over 70 and only have a 'pay as you go' mobile phone,. I've rung BT and they advised me to call Sky.
Message posted on 23 May 2024 11:37 AM
@bunnie yes, Sky Talk Shield works with Sky Internet calls. You may have to re-register use of the Shield with Sky when the switch to Internet calls has completed on your line.
Message posted on 23 May 2024 11:44 AM - last edited: 23 May 2024 11:48 AM
'BT' in this context is just another ISP in competition with Sky.
BT Wholesale and Openreach, which are pushing forward with PSTN switch-off, aren't public-facing organisations.
The target end-date for the project itself has just slipped by more than two years.
https://www.bbc.co.uk/news/articles/c5119g5z4q5o
Message posted on 23 May 2024 12:27 PM
Thank you for your reply and the interesting article on the link provided.
Message posted on 23 May 2024 12:29 PM
Thank you for your reply which is very reassuring!
