6
This discussion topic has been answered Discussion topic: Crakling noise on calls
This message was authored by: JD402
I have a BT cordless phone set which has now developed a crackling sound on all calls in and out which makes it difficult to hear.
This has happened before but I can't remember what solved the problem last time
Re: Crakling noise on calls
@JD402
If you haven't done it yet try the below line test. Disregard it saying it will test your broadband
https://www.sky.com/help/articles/fix-phone-problems-start
@JD402
@JD402 does your phone plug into your broadband Hub? Or into a wall socket?
If it's a wall socket, does it have separate ports for broadband and phone? Or just one?
Do you have a standard,corded phone you could try, to rule out a problem with your cordless phone?
Avatar for JD402
Yes my phone plugs directly into a BT wall socket which has separate ports for phone and broadband.
No I havent got standard corded phone
Thanks @JD402 . Any luck with the connection test in @Daniel0210s post?
Avatar for JD402
Yes that seems to have worked
Many thanks
@JD402 yes, sometimes just running the test clears it. If the fault returns, let us know.
