13
This discussion topic has been answered Discussion topic: sky + not working
This message was authored by: Col131
sky + not working
initially thought it was just the rc not working.
Changed batteries
Used rc from other telly
Found that wasn't working either
Came back to original telly to see messgae: "Unsupported signal. Check your device output."
Any ideas anyone?
This message was authored by: Mark39 Answer
Re: sky + not working
Try switching both your TV and your Sky box off at the plug for 4 minutes. Failing that you may need to consult your TV manual.
I'm assuming you have Sky+ (where you've posted) as you haven't posted otherwise.
You have posted in the Sky+ forum, do you have Sky+? as that description does not describe a Sky+ error 😞
Any ideas anyone?
That's a TV error message, not Sky. Try turning off your TV at the plug for 30 seconds or so,
Avatar for Col131
Thanks for advice, but didn't work!
TV in kitchen is saying:
"Mode not supported
HDMI 1
Resolution not supported. Change the resolution9of the external device."
Anyonee got any ideas on how to resolve this, please?
Avatar for Col131
Yes, it is SKY + that I have.
As both TVs have been affected, I was assuming SKY + as rhe common denominator.
Avatar for Col131
OK, I'll try that....although its both TVs, so assumed Sky as common denominator. And yes, it is Sky + I have.
Thanks and I'll let you know either way!
Avatar for Col131
Thanks to both people who replied - problem has been resolved!  Think the Sky + box may be on the way out as this is the second problem in the past two weeks.
Thanks again and Happy New Year when it comes!
It is time switch off your Sky+ SD box and get a Sky+ HD box or Sky Q🤔
This message was authored by: GeorgeDrever
Re: sky + not working friend who is excellent at sky problems gave up and said contact Sky
Sky TV not working
Friend did his best for nothing
dish ok
no cnnection
Tried switching off and on still nothing
Screen says no satellite signal
Nothing to reply to?
How do you know the dish is ok because if it has moved ever so slightly it can cause issues with the signal. If you have also checked the cables then you will need to contact a local company to come out and look at it as Sky no longer do home visits for Sky+ boxes.
Please Note: Sky+ is now a legacy service that Sky are winding down
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
