Discussion topic: reporting a fault
This message was authored by: Philip106
reporting a fault
My sky box is reporting no signal
Re: reporting a fault
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
