Discussion topic: replacement sky remote controller for a Panasonic TV model R024,092.11.00P
This message was authored by: Ron54
I have  a Panasonic TV model R024.092.11.00P   and I require a replacement remote.  Please can you tell me where I can buy one that will work with this TV
Thank you
Re: replacement sky remote controller for a Panasonic TV model R024,092.11.00P
I'm confused, you are using the Sky box software version as a model numnber for your TV
@Ron54 that looks like a Sky box software version number, not a TV model number.
To my knowledge, the only versions of the remote for a Sky+ box currently on sale are a Rev10 and possible an earlier Rev9.
If your existing remote has the same Rev number a replacement should have the necessary code for your TV.
