Discussion topic: Replacement cable
This message was authored by: AH6827
Replacement cable
Hi my sky will not connect to internet I've noticed the cable that is in my phone socket at the sky end has some wires hanging out how do I replace this ? Is there any way I can send a photo?
Re: Replacement cable
You may totally remove this cable as it is only used with the boxes built-in dialup modem (no longer used), it has nothing to do with broadband as this is obtained via either wifi or the RJ45 socket to the broadband  router
To send pictures to the forum click the camera icon when composing your post
