Discussion topic: problems with accessing talking pictures tv
This message was authored by Vic+the+stick This message was authored by: Vic+the+stick
we have scrambled satellite signal on this channel and  also with TCM,
Re: problems with accessing talking pictures tv
@Vic+the+stick  It's isn't scrambled as you put it it sounds more like picture breakup due to one of 2 things:
Your dish is slightly out of alignment, or it's a channel issue with the uplink.
Are any other channels affected.
This message was authored by Mark39 This message was authored by: Mark39
You mean the picture is pixelated - broken up into coloured lines and squares? Check your signal strength (Services > Settings > Signal) while tuned to these channels. The white part of all 4 bars should be at least half way across.
On average, new discussions are replied to by our users within 100 minutes
