Discussion topic: multi room
This message was authored by: VJ811
multi room
I live alone , get sky in dining room (used as living room)
I have sky + hd box can I get multi room box for the lounge only
Re: multi room
@VJ811
No. Sky+ is no longer supported by Sky and therefore additional boxes are not available. You need to consider upgrading to Sky Q.
Re: multi room
@VJ811 as @Daniel0210 posted, Sky+ is now obsolete and Sky won't provide an additional box or the Multiscreen subscription you would also need.
An alternative to upgrading might be to use the RF2 output on your Sky box to provide a direct connection to your lounge tv via a length of coax cable. A,tv link (magic eye) would enable you to control your Sky box from the lounge. The only proviso is that your lounge tv must be equipped with an analogue tuner as well as digital.
