Discussion topic: ITV and channel 5 not working
This message was authored by: Carolwest1
Channel 5 and itv are not working - Cole's up with an error saying that the box is not getting signal. We have restarted, recalibrated etc and nothing has worked
Re: ITV and channel 5 not working
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
