5
This discussion topic has been answered Discussion topic: entering numbers and letters using Sky remote
This message was authored by: Malc17
how do you enter numbers and letters using your sky remote control
Re: entering numbers and letters using Sky remote
@Malc17
Keep pressing the number that matches the letter you want on your Sky+ remote.
@Malc17
Avatar for Malc17
Thank you
This message was authored by: roger716
On my old-style Sky remote when I try to input 7 it come up with Q- (the dash meaning it's looking for the next letter input). No amount of holding down the 7/Q key will move it from Q to 7.
What am I doing wrong?
For info, I'm trying to input an all numerical password to connect to my Wifi Network.
IIRC you don't hold down the button, you need to press it quickly to cycle through the letters/numbers
Many thanks for putting me on the right track. It's easy when you know how!
