Discussion topic: No satellite signal
This message was authored by: Jamie216
No satellite signal
Hi I have no satellite signal after yesterdays storm. I have tried resetting the box however this has not helped.
Avatar for Jamie216
Level 0 icon
Re: No satellite signal
I have tried resetting however this has not helped
@Jamie216
If your dish has moved then resetting the box is unlikely to fix it so as Sky do not support Sky+ setups you will have to use a local company to come out and look into this for you.
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
