Discussion topic: Weak signal from my sky + box
This message was authored by: Terry191
Ii keep getting a very weak signal for my sky + hd box so I'm barely getting any channels to watch th signal keeps coming and going I've spoke to Sky advisor and they blame the software as the sky box are not getting software updates, I don't really want to get sky Q box this weak signal issue has been happening for around 4 weeks is there other people with sky + he box having the same problems
Re: Weak signal from my sky + box
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
@Terry191 I doubt it's a software problem. Much more likely a fault with your dish setup as @Annie+UK posted. if you wish to avoid upgrading to Sky Q, follow @Annie+UK's advice.
Bear in mind though that all hard disks fail eventually and as yours is now at least 10 years old it's likely to be on borrowed time (it would have nothing to do with your current signal issue, though.).
That's a misunderstanding: while it's correct that as an end-of-life platform Sky+ HD no longer receives functionality updates (and hasn't done so for a considerable time) this is entirely unrelated to any satellite signal issue.
