9
This discussion topic has been answered Discussion topic: Viewing Card
This message was authored by: SusieY
Viewing Card
it says my Viewing Card is not authorised. I have gone to Details on my tv and given my last 3 digits and they haven't been recognised
Re: Viewing Card
There is no magic number for a quicker response @SusieY
Some suggest about 7pm is a little quieter but who knows.
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Viewing Card
@SusieY clearly this isnt a boadband issue which Sky TV system thst uses viewing cards do you hzve Sky Q or SkyHD+?
Avatar for SusieY
Re: Viewing Card
My Sky box is Sky+HD
Re: Viewing Card
Have you ordered Sky Q at any point recently?
Avatar for SusieY
Re: Viewing Card
Yes, but they weren't able to fit the disc so it was cancelled
Re: Viewing Card
That would be the reason. When you order Sky Q your Sky+ Viewing Card is scheduled to be disabled. Unfortunately that's not reversed if your Sky Q order doesn't complete, for any reason.
If you give Sky a call, they should be able to reinstate your existing Card or send you a new one. Be ready for them try to sell you Sky Q (again) or Sky Stream.
Avatar for SusieY
Re: Viewing Card
Thank you but it's not that easy to speak to anyone at Sky - I tried earlier and after an hour I gave up!  Do you have a magic number?
Re: Viewing Card
Avatar for SusieY
Re: Viewing Card
Thank you I'll try after supper
This message was authored by: Tony+R.
Re: Viewing Card
On a similar note ....
I have just spoken to Sky 'help' regarding a Sky+HD box viewing card that I wanted pairing and authorising.....
SKY are not supporting Sky+HD anymore.
I was advised that the card I had was now 'switched off' and could not be reinstated AND Sky were not issuing any more Sky+HD viewing cards.....so my box is now just a Freesat receiver and recordings and other services are not accessible.....
