Discussion topic: Upgrading from Sky + to what?
This message was authored by: GLloydV
I've been with sky for 22 years now but am now a little behind. Even though I have been paying for multi room all year I only have one sky box which is sky +. Its very old now so time to upgrade but to what? Sky Q and use the muti room to add a second tv orrrrrrrr sky glass but does that have multi room.
Re: Upgrading from Sky + to what?
@GLloydV
The equivalent to Multiroom in Sky Q is Q Mini boxes over WiFi with a Multiscreen subscription.
In Glass it's Stream pucks with a Whole Home subscription.
There's also Stream by itself (no Sky-branded television set)
Note that Glass/Stream is not an 'upgrade' to Sky+ : it's a very different system.
The 'upgrade' from Sky+ is Sky Q, although note Q does not have Reminders or Slow Motion.
Avatar for GLloydV
If I was simply to remain with the single TV, and baring in mind that my sky + box is VERY old now, whats better to go for, Sky Q or change sytem to Glass?
@GLloydV
I'd suggest Sky Q, but be very clear with Sky that you want no increase in monthly cost and no up-front installation fee, otherwise they'll sneak in a Q Mini and charge you for it.
Avatar for GLloydV
Great, thanks for your help
That sounds like it needs to be done over the phone or is there an email or online chat that works?
@GLloydV
If your Sky+ box is not an HD model, I'd suggest this route:
https://www.sky.com/help/articles/bbcupgrade
and beware of the inevitable upselling ; )
