4
This discussion topic has been answered Discussion topic: Update my sky box
This message was authored by: JanetCuthbert
Update my sky box
I need a new sky box as mine is very old
This message was authored by: Mark39 Answer
Re: Update my sky box
Sky+ equipment is now obsolete and can't be replaced. Give Sky a call to discuss an upgrade either to Sky Q or Sky Stream. .
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass, Sky Stream and Sky Q (Satellite TV is approaching end of life so is not a long term solution)
You will need you "upgrade"
@JanetCuthbert
You've posted on the Sky+ board.Sky+ is no longer supported by Sky. You can't get a different box to work.
Contact Sky to potentially upgrade to Sky Q or change to Glass / Stream.
@JanetCuthbert
The youngest Sky+ HD box is now a decade old: they ceased manufacturing in 2015 to make way for Sky Q (which is itself now being replaced)
