Discussion topic: Timing out setting
Message posted on 15 Apr 2025 07:07 PM
Timing out setting
My tv appears to time out but this is featured is not enabled in the tv settings so assuming this is a fu action if my SKY + box. Where can I find and change this setting?
Message posted on 15 Apr 2025 08:01 PM
Re: Timing out setting
What's happening when it times out?
Message posted on 15 Apr 2025 08:18 PM
@ChrisFincham wrote:My tv appears to time out but this is featured is not enabled in the tv settings so assuming this is a fu action if my SKY + box. Where can I find and change this setting?
I believe that the Sky+HD Box will turn off if the remote isn't used for 4 hours. I don't think there's a way to change this.
Is this what you mean?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 15 Apr 2025 10:14 PM
Yes, thanks
Message posted on 15 Apr 2025 10:15 PM
Blank screen
