Discussion topic: Technical issue with all channels
This message was authored by: Laura385
Every channel says technical issue with this channel, try again later. This has been for nearly 24 hours now
Re: Technical issue with all channels
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q for Signal Strengths/Qualities
Doesn't sound like a Sky+ issue, where you've posted.
Do you have Sky Stream or Glass? If so, restart your Puck/Glass by turning off at the plug for a few minutes.
