Discussion topic: Tech
This message was authored by: Anne127
Tech
Sky +hd box is working but I can't watch tv because I keep getting the message searching for channels.
Re: Tech
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q for Signal Strengths/Qualities
Re: Tech
If the message is as you posted, it doesn't sound like a Sky box error.
It sounds like a message from your TV.
Avatar for Anne127
Re: Tech
Thank you. for your help .
There was a problem with the service in the block of flats where I live.
It has now been fixed and everything is working fine.
