Discussion topic: Switch from Sky+ to Sky Stream
This message was authored by: ciaran01
Is it possible to switch from Switch from Sky+ to Sky Stream - when i try on the website, it says
"As a Sky TV customer, you already have the best entertainment from Sky. The award-winning Sky Glass gives you the flexibility to playlist your favourite shows across multiple platforms and watch in pixel perfect quality."
And it directs me to sky glass?
Thank you
John
Re: Switch from Sky+ to Sky Stream
If you are sure Sky Stream is what you want then you should be able to do this by calling Sky. Note that you will not be able to go back to Sky+ should you change you mind as you would have to go with Sky Q instead.
Avatar for ciaran01
Thank you very much - do you know if the channel list for Stream is the same as Sky+ "Variety"
Variety is an old package no longer available so it will be different. This link should help:
https://www.sky.com/help/articles/tv-channel-list-sky-glass
Very unlikely. You can find the SkyGlass/Stream channel list here: https://www.sky.com/help/articles/tv-channel-list-sky-glass
