Discussion topic: SkyHD box not working
This message was authored by: Mariajohn21
My dky HD just says its installing
Re: SkyHD box not working
Do you mean 'initialising'? That's usually because it's not receiving a signal from your satellite dish. First try turning the box off at the plug and checking thay the dish cables are securely fitted to the sockets at the back.
Is it a Sky HD box or Sky+ HD box?
