Discussion topic: Sky viewing cars needs pairing.
This message was authored by: Pauline89
The message "your sky viewing card needs to be paired to your sky+HD box."  Has appeared on the screen.   I can't pair it.   I have tried various things from the quick fix help page.
Re: Sky viewing cars needs pairing.
Is this the same Sky box and Viewing Card that were in use last October?
Avatar for Pauline89
Yes nothing has changed.  Just wouldn't work when I turned sky on
@Pauline89 you'll have to give Sky a call, I'm afraid, of you can't pair them yourself. Don't let them tell you you'll have to upgrade- it's not correct.
Thanks mark.   I will give them a call in the morning.  Any idea why it should need pairing ?
None, I'm afraid. But we've seen it reported here before.
Really appreciate your help.   All the best.
