Discussion topic: Sky tv
This message was authored by: Divine2
Sky tv
Tv not coming on
TV says
check the aerial connections and saved channels
Re: Sky tv
@Divine2 is the power LED green on the front panel of your Sky box?
The message is from your tv - check that the tv is switched to the correct HDMI input for your Sky box
Avatar for Divine2
Re: Sky tv
Tv still says weak or no signal after checking all cables please
thanks
Re: Sky tv
thanks
That message has nothing to do with Sky TV, that message is for the Freeview signal that is via your terrestrial aerial
Re: Sky tv
@Divine2
